Problem removing image from rhino viewport - please help!
Sorry this is my first time here. I’m having a lot of issues with my render viewport.
There is a weird image popping up in my render view port in Rhino. It is of an image that I never put in and I cant seem to remove it. It takes over the entire render viewport and when I move my model, it moves around the image (360 degrees).
It isn’t a bit map background image either since I have tried adding/removing one. It shows up only in render mode. It doesnt seem to be a v-ray issue since I have checked my environment settings.
Please help!
There is also this weird vignette thing happening on my viewport too:
-Natasha
You have an Environment established.
In the Render pull-down, click on Environment Editor.
You’l;l see something called ‘Rhino Interior’ That’s an image we supply to give renderings something realistic to reflect.
Right-mouse click on it and choose Delete.
That will get rid of it.
It’s also possible this image was set as a viewport “Wall paper” image.
If that’s it, right click on the Perspective viewport name, choose Viewport Properties, and uncheck the Show Wallpaper option.
Thanks so much John, I’ve had prolonged issues with environments overworking my CPU and crashing, it’s finally good to not have Rhino 6 causing laptop fans to go flat out cause I’ve finally deleted the environments I had loaded. Be interesting to see if, next time I try a render and load something like Rhino Sky, it heats up the CPU again…
