Problem printing
I have a problem printing, print me only half sheet, all displays and components are active. I do not know what to do. Someone could help me?
2.pdf (606.5 KB)
2.pdf (606.5 KB)
Please, note the red line, there is in the Rhinocerso, but it isn’t in the PDF…
Hi Daniele- please post the Rhino file - if it is private, please send to tech@mcneel.com and someone will have a look.
Good morning,
I’ve a problem with the dimension file… It’s more or less 90 MB… How
can I do to give you the file?
thanks
Cordiali saluti / Best regards
Ing. Daniele Perazzolo
Uffico Tecnico - Technical Engineering
Daniele.Perazzolo@tma-winding.com
You can use the upload functionality here:
http://www.rhino3d.com/upload
Yes, I flagged the link for McNeel to look at. --Mitch
Daniele, the file prints correctly here using CutePDF as the driver, for what it is worth, in my case . What PDF driver are you using?
(http://www.cutepdf.com/products/CutePDF/writer.asp)
thanks,
