Anyone have a solution to this issue?
Left work yesterday being able to print pdf layouts fine, come back this morning and go to update a layout and it is showing just this black screen as seen in screen grab below:
For example: Did you close Rhino when you left and reopen it the next day? Did you turn off the computer overnight? Did Windows perform an update overnight if you left the computer on?
Finally: did you try closing everything down and rebooting the computer?
I did not close Rhino when I left, to my knowledge my computer did not shut off, reboot or preform any windows updates after I left.
I have rebooted my computer as well as closed and rebooted rhino a handful of times.
Since I posted this, I have noticed that there has been a few bugs since starting work this morning. such as some display views are not looking the way they usually do:
Here is the systeminfo:
Rhino 6 SR35 2021-8-10 (Rhino 6, 6.35.21222.17001, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Commercial, build 2021-08-10
License details: Cloud Zoo. In use by: jpeterson (StudioCraft)
Windows 10.0.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: OMEN
Secondary graphics devices.
NVIDIA GeForce GTX 1080 (NVidia) Memory: 8GB, Driver date: 1-29-2020 (M-D-Y).
> Integrated acclerated graphics device (shares primary device ports)
- This device is not being used
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 1-29-2020
Driver Version: 26.21.14.4219
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 8 GB
Is your laptop plugged into an external monitor? If so, try unplugging the monitor and restart Rhino to see if things work better. @jeff do you have any recommendations?
Thanks Steve, it was hooked up to two monitors, unplugged both of them and still the same issue…
I’m guessing my issue is this:
ATTENTION:
Is there a way to direct Rhino to see the graphics card?
So, you also left work yesterday being able to print pdf layouts just fine, come back this morning and find just a black preview in the print dialog?
Do you know if something might have happened to your machine between yesterday and today?
Please run the Rhino SystemInfo command and copy-paste the result here.
