Printing Extra Layouts
I am having an issue printing all layouts to PDF, where the print dialog is showing more layouts than I have in my file. When I print it duplicates some pages in the file. I have had this issue on nearly all my files, so this is not isolated. Also, many of my coworkers have the same issue.
I have switched to multiple PDF printers and they all have the same issue. See an example of the issue shown below. Rhino file attached as well
18037_Brandaw_Trellis_Mod_02_PRINT_Issue.3dm (5.6 MB)
Hello- I think you may have an outdated Rhino - try getting the latest.
https://www.rhino3d.com/download/rhino-for-windows/7/latest
I have updated and still have the same issue. I opened a blank template file and the issue exist when you copy layouts. With 1 layout it prints proper, then as soon as I copy that layout the bug appears.
Thanks for your help
Hm - that is this item -
RH-63929 Print: Copied layout was printed more than once
Which was fixed and tested - it looks like it may be in the current release candidate
you can get the (hopefully) fixed version by changing the ‘Update frequency’ in Options > Updates and Statistics page to ‘Service release candidate’
Any better?
It seems to have been solved with the most recent release candidate. Thanks for your help
