I use CutePDF Writer to print large format drawings.
The resolution of the drawings is low, the lines are jagged. How can I increase the resolution to avoid the problem?
I imagine it’s CutePDF thing. I use PrimoPDF and have no problems.
Usually you can adjust resolution in your printer driver. If you click on the “Properties” button in the Rhino print dialog, this will take you to the printer driver settings page. I don’t have Cute PDF installed, but I would imagine that would work.
I had already tried. The problem is that I have to print a drawing that measure 78,74x40,95 inches and when I increase the printing quality, for example, 1200 dpi
save only a white A4 paper with no image.
