A few weeks ago my viewport preview stopped showing the viewport in the print dialogue (ctrl+P). All I get is an empty canvas. Nothing appears on print to PDF either.
System settings:
Just to check - are the scale/margins/positions set up correctly so the stuff to print fits in the window?
Are you printing from a layout? Is Layout checked under View and Output scale?
Hei Kristian -
Please post the entire SystemInfo data as text.
Rhino 7 SR24 2022-11-4 (Rhino 7, 7.24.22308.15001, Git hash:master @ cb2ad12922ceb989b185972675bb705a00abb97d)
License type: Commercial, build 2022-11-04
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics 620 (Intel) Memory: 1GB, Driver date: 1-22-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 12-5-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 527.56
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 3.3
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-5-2022
Driver Version: 31.0.15.2756
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.0.3.0
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Modelur.Windows (ad2483aa-a880-4b0d-b6e5-2ac16f572543)\2022.8.1.0\Modelur.Windows.rhp “Modelur.Windows” 2022.8.1.0
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SIMO-Rhino\1.0.5.3\UIM.Rhinoceros.rhp “SIMO-Rhino” 1.0.5.3
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.24.22308.15001
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.24.22308.15001
Takker -
Could you select everything on that layout and run Export, then select the PDF file format. Does that show a preview?
Thanks for checking that, Kristian -
Is this with any file? Like a new file from a factory-default template with only a simple rectangle that can be seen in one detail on a layout?
Try disabling all of these plug-ins in the pluginmanager and restart Rhino. Does the print setup window still have an empty preview?
I have tried disabling the plug-ins as suggested - but still empty print setup window, unfortunately.
Expand the visibility section of the print dialog. Do you have selected objects only checked?
