I have a workstation whose only function is to run our laser-cutter. We “print” directly from Rhino model space to the laser cutter, and sometimes people forget to check that the scale is 1:1, and parts end up sized incorrectly.
Is there a way to set the default print scale in model space to 1:1?
Thanks for the help!
hank
theoutside
(Kyle Houchens - McNeel and Assoc. )
#2
make a new blank file and then set the print settings to what you want. Save it as a template named 1-1 template.
when you start a new part, open that template 1st, then import your parts into that template.
it should keep those settings unless someone overwrites them.
