I have a file with four layouts, each has a single detail view showing the model from a different angle using the “Rendered” view setting. Attempting to print or save to PDF using the print dialog causes Rhino to crash. Tried the following:
- Change all detail views to Wireframe (prints OK)
- Change all detail views to Pen (still fails)
- Change paper size (same issue)
- Change print driver (same issue)
Have also noticed the performance of the View Capture to File and View Capture to Clipboard commands is super error-prone in R6 for Mac Beta, wondering if this could be related somehow? I’ve been getting results with random white streaks through the image (when using “Scale” other than 1) and objects rendering as solid black instead of a normal display color or rendering material when using Transparency.
from “Rhinoceros Information”:
Rhino 6 SR16 2019-6-4 (Public Build, 6.16.19155.12084, Git hash:master @ cc3dd299fd2baa25b3a14b0498296db9526ae6fd)
License type: Beta, build 2019-06-04
License details: Stand-Alone
Expires on: 2019-07-19
Apple Intel 64-bit macOS Version 10.14.3 (Build 18D109) (Physical RAM: 8Gb)
Mac Model Identifier: MacBookPro11,1
Machine name: Carsten’s MacBook Pro
Language: en-US (MacOS default)
Intel Iris OpenGL Engine (OpenGL ver:4.1 INTEL-12.4.7)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: 24 bits
Total Video Memory: 1536 MB
Graphics: Intel Iris
Displays: Color LCD (256dpi 2x)
Graphics processors
Intel Iris (1536 MB)
Color LCD (1440 x 900)
USB devices
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
Rhino plugins
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.16.19155.12084
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.16.19155.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.16.19155.12084
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.16.19155.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.16.19155.12084
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.16.19155.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.16.19155.12084
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.16.19155.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 6.16.19155.12084
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.16.19155.1002
