Hi
V5
draw line , give it thickness 0.5, turn on print preview for that window
export as ai and import into photoshop at same image size, but its hardly visible at same size as image in rhino.
If one creates a line of thickness e.g. 0.5mm in a vector prog, and export as eps, it will open as that thickness.
One can draw a map with Motorway 3mm and B roads 1mm and they open into photoshop as such via eps.
as such its impossible to get any artwork into photoshop from Rhino.
This is serious bad news. All plans on using rhino to put artwork into photoshop are sunk.
What is the solution, why are graphic print line thicknesses not supported in a graphics route ?
This works going to Illustrator - no telling what PS is doing with it though. I don’t have PS here, - does it open vector PDFs? I’d think so - try that.
