Is there a way to make a file save state of print display? I like working with it on, but every time I close and reopen a file I have to turn it on again.
This is an old questions but I’m having the same issue… print display seems to reset every time I restart rhino. How do you set it to on permanently?
Wow this is a blast from the past. Completely forgot I asked it but it would be helpful. I’ve not tried it recently in the V6 WIP since I’m mostly focussing on rendering type stuff at the moment rather than line drawing output, but yes, it was really weird that it kept turning off.
Hello - you can put
_PrintDisplay _State=_On _Enter
in your startup commands in Options> General page.
Thank you!!!
This is great, but I think it would be good to be able to choose it by model. For example, some files you may want print display to stay on at all times, others you may not want it on at all.
Just piling on here to agree. It would be super nice if the state of print display were saved in the file. I want it on for some views, off for others. I have a big file with lots of layouts, views, ect.
Yes, you’re right: it should be possible to set by view rather than by file.
What would be really cool is to be able to set some objects to always or never have print display turned on. Not sure how the UI would work for that though.
Hello, I am on V8 for Mac, and I have a related problem, which I never experienced on Windows.
I understand that PrintDisplay settings are set globally for the whole program, but what is happening for me on Mac is that whenever i switch PrintDisplay State On with multiple windows of the program, it switches off on the other window, which tells me that instead of globally assigning the value to be on, it toggles the value for every drawing. And it is impossible for me to synchronize the settings in all open windows of the program. Which means that going between different drawings is maddening.
I might be missing something, but the fact that I never experienced this on windows tells me that it might not be expected behavior and is probably related to how MacOs treats instances of open files in Rhino vs how Windows treats them as every program running separately…
If any one knows the solution to this, I would greatly appreciate it.
