hello, I just discover that I can drop in materials in rhino layer directly by the folder’s materials (Render Content).
I think I mess up and select open the material with Photoshop. Now I am unable to see the preview of the material as previously How can I change it , which program allows the preview display?
I’m not sure it will help but you can try this trick.
in location where you have those files, right click on them and go properties, then where you have “open with” click change and chose rhino.
Hi, i am having the same issue and the view in explorer the same in al folders(I cant see any files preview). And also i run the DownloadLibraryTextures command also.
Problem solved with TestRestoreLibraryFileAssociations command. Thanks!
