Pressing a button in an ETO form crashes rhino
I have a very basic ETO form with a single button which when pressed should print some text. Pressing the button crashes rhino.
import Rhino
import Eto.Drawing as drawing
import Eto.Forms as forms
class MainWindow(forms.Form):
    def __init__(self):
        self.Title = "test button"
        self.Padding = drawing.Padding(5)
        self.Resizable = False
        self.buttonTest = forms.Button(Text = "test")
        self.buttonTest.Click += self.OnTestButtonClick
        layout= forms.DynamicLayout()
        layout.AddRow(self.buttonTest)
        self.Content = layout
    def OnTestButtonClick():
        print "it works!!"
def OpenMainWindow():
    form = MainWindow()
    form.Owner = Rhino.UI.RhinoEtoApp.MainWindow
    form.Show()
if __name__ == '__main__':
    OpenMainWindow()
testButtonCrash.py (778 Bytes)
It seems to be due to the fact that I use a modless form. It works properly if I use a modal dialog.
I was able to make it work with a semi modal dialog (see code below).
import Rhino.UI
class MainWindow(forms.Dialog[bool]):
    def __init__(self):
        self.labelTest=forms.Label()
        self.labelTest.Text="this is a test"
        layout.AddRow(self.labelTest)
    def OnTestButtonClick(self, sender, e):
        self.labelTest.Text="it works!!"
    form = MainWindow()
    Rhino.UI.EtoExtensions.ShowSemiModal(form, Rhino.RhinoDoc.ActiveDoc, Rhino.UI.RhinoEtoApp.MainWindow)
    OpenMainWindow()
