I am trying to get collapsable form implemented. And I am having a crash issue caused by lines 69 and 75. When the dialog tries to get resized.
If I comment those out they “work” as in text shows up and get’s hidden.
But as soon as its uncommented it just brings everything down.
I am using this as an example
Here is what I have right now.
Clearly, there is a syntax issue or something, I just can’t figure out what I should change to get it to work correctly.
Any advice is much appriciated.
import System
import Rhino
import Rhino.UI
import Eto.Drawing as drawing
import Eto.Forms as forms
import scriptcontext as sc
__commandname__ = "viAttributeShow"
class viAttributeShowModelessForm(forms.Form):
# Initializer
def __init__(self):
self.m_selecting = False
# Basic form initialization
self.Initialize()
# Create the form's controls
self.CreateFormControls()
def Initialize(self):
self.Title = 'Show Attributes'
self.Padding = drawing.Padding(5)
self.Resizable = True
self.Maximizable = False
self.Minimizable = False
self.ShowInTaskbar = False
self.MinimumSize = drawing.Size(200, 150)
# button to toggle collapsing
self.collapseButton = forms.Button(Text = '+', MinimumSize = drawing.Size.Empty)
self.collapseButton.Click += self.collapseButton_Click
# FormClosed event handler
self.Closed += self.OnFormClosed
# set content of the collapsed section
self.collapsePanel = forms.DynamicLayout(Visible = False, Padding = drawing.Padding(40, 10), DefaultSpacing = drawing.Size(5, 5))
self.collapsePanel.AddRow('Some text 0')
self.collapsePanel.AddRow('Some text 1')
self.collapsePanel.AddRow('Some text 2')
self.collapsePanel.AddRow('Some text 3')
self.collapsePanel.AddRow('Some text 4')
self.collapsePanel.AddRow('Some text 5')
self.collapsePanel.AddRow('Some text 6')
# Create all of the controls used by the form
def CreateFormControls(self):
# Create table layout
layout = forms.DynamicLayout()
layout.Padding = drawing.Padding(10)
layout.Spacing = drawing.Size(5, 5)
layout.AddSeparateRow('Text', None, self.collapseButton)
layout.AddCentered(self.collapsePanel) # we need this auto-sized so we can get its width to adjust form height
layout.Add(None); # expanding space, in case you want the form re-sizable
#layout.AddSeparateRow(None, 'Refresh Button', 'Close Button');
# Set the content
self.Content = layout
def collapseButton_Click(self, sender, e):
try:
if self.collapsePanel.Visible:
#self.Content.ClientSize = drawing.Size(self.Content.ClientSize.Width, self.Content.ClientSize.Height - self.collapsePanel.Height)
self.collapsePanel.Visible = False
self.collapseButton.Text = '+'
else:
self.collapsePanel.Visible = True
self.collapseButton.Text = '-'
#self.Content.ClientSize = drawing.Size(drawing.max(self.Content.ClientSize.Width, self.collapsePanel.Width), self.Content.ClientSize.Height + self.collapsePanel.Height)
except:
print "Unexpected error:", sys.exc_info()[0]
pass # so we don't bring down rhino if there's a bug in the script
# Form Closed event handler
def OnFormClosed(self, sender, e):
# Dispose of the form and remove it from the sticky dictionary
if sc.sticky.has_key('attribute_show_form'):
form = sc.sticky['attribute_show_form']
if form:
form.Dispose()
form = None
sc.sticky.Remove('attribute_show_form')
# TestViAttributeModelessForm function
def TestViAttributeShowModelessForm():
# See if the form is already visible
return
# Create and show form
form = viAttributeShowModelessForm()
form.Owner = Rhino.UI.RhinoEtoApp.MainWindow
form.Show()
# Add the form to the sticky dictionary so it
# survives when the main function ends.
sc.sticky['attribute_show_form'] = form
def RunCommand( is_interactive ):
print "Running", __commandname__
# Check to see if this file is being executed as the 'main' python
# script instead of being used as a module by some other python script
# This allows us to use the module which ever way we want.
if __name__ == "__main__":
RunCommand(True)
