Eto.forms - close on button click and get values from text box
Hi to everyone,
I am developing a simple plugin in rhino with few commands. I started to learn how to use Eto.Forms for inserting data to rhino. My question is, how can I close the form on button click event. I looked all over this forum, GitHub and others. Found some examples, but it does not work for me. I have similar Eto.forms written in Python and it does work. When I try to convert python code to C# (I am C# beginner) I cannot make my form close.
Thanks for any kind of help
Ondřej
My code:
using Rhino;
using Rhino.Commands;
using Rhino.Input.Custom;
using Eto.Forms;
using Eto.Drawing;
namespace SampleCsEto.Commands
    public class EtoSample1 : Rhino.Commands.Command
        public override string EnglishName => "EtoSample1";
            var f = new SampleCsViewportForm();
            f.Show();
            GetPoint GetPnt3D = new GetPoint();
            GetPnt3D.SetCommandPrompt("Select reference point on 3D curve where axis will be positioned");
            GetPnt3D.Get();
                return Result.Success;
    internal class SampleCsViewportForm : Form
        TextBox TB1 = new TextBox();
        TextBox TB2 = new TextBox();
        string X = "";
        string Y = "";
        public SampleCsViewportForm()
            Title = "Hokus pokus";
            Resizable = true;
            Label L1 = new Label();
            Label L2 = new Label();
            Button B1 = new Button();
            Button B2 = new Button();
            L1.Text = "X move";
            L1.TextAlignment = TextAlignment.Left;
            L2.Text = "Y Move";
            L2.TextAlignment = TextAlignment.Left;
            B1.Text = "Ok";
            B1.Click += OnOkButtonClick;
            B2.Text = "Cancel";
            B2.Click += OnCloseButtonClick;
            TableRow TR1 = new TableRow();
            TR1.Cells.Add(L1);
            TR1.Cells.Add(TB1);
            TableRow TR2 = new TableRow();
            TR2.Cells.Add(L2);
            TR2.Cells.Add(TB2);
            TableRow TR3 = new TableRow();
            TR3.Cells.Add(B1);
            TR3.Cells.Add(B2);
            this.Content = new TableLayout
                Padding = new Padding(20),
                Spacing = new Size(10, 10),
                Rows = {TR1,TR2,TR3}
        public void OnCloseButtonClick (object sender, System.EventArgs e)
            Close();
        public void OnOkButtonClick(object sender, System.EventArgs e)
            X = this.TB1.Text;
            Y = this.TB1.Text;
            Close();
Hi Ondřej, have you tried this.Close() yet ?
_
c.
Hi Clement. It does work with this.Close(). As VS told me that “this” is not needed I went without it. .
If I understand it well, without “this” Rhino does not know to which class Close method linked. Am I right?
Thanks a lot.
right.
_
c.
