Possible to disable component such as mirror via a boolean toggle or slider? Or maybe another method for control via galapagos.
Use stream gate and stream filter components to create different paths around your definition so one path (true) could execute a part of the definition using mirror. Another path (false) could execute a part of the definition not using mirror.
That sounds perfect, I’ll give it a try, thank you Michael!
