Hello, after subdividing this model extrude not visible in the Gumball
Cheers
Joao
PossibleProblem.3dm (155.8 KB)
Cheers
Joao
Yes, same here, but only if SubD-Reflect applied.
Thanks
@rhinofan
And same issue with Subd _Radiate.
Best regards
Hi Joao - as far as I can see this works here on our latest in-house builds. Can you run SystemInfo in Rhino and cpoy/paste the results here?
Hi Pascal, here it goes
Rhino 7 SR7 2021-5-18 (Rhino 7, 7.7.21138.11001, Git hash:master @ 175cf0b9405e059f3075a5720c0c37a9d52b6a5c)
License type: Educational, build 2021-05-18
License details: Stand-Alone
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 7.9Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display: Intel(R) HD Graphics Family (Intel) Memory: 1GB, Driver date: 3-8-2017 (M-D-Y).
Primary OpenGL: NVIDIA GeForce 840M (NVidia) Memory: 2GB, Driver date: 12-18-2017 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 388.73
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-18-2017
Driver Version: 23.21.13.8873
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Hi Joao - I’d start by updating the drivers of both GPUs to the latest available from the Intel and NVidia websites.
Thanks Pascal. By the way, if I break the Reflect, the problem disappears
Hi Joao- did new drivers fix it more thoroughly?
I have not yet updated. I have some high responsability work to be done this week and will wait for next week to try the updates
@pascal
Last driver installed, bug still present. *RH 7, 7.7.21131.13001
Regads
If after subdividing I use the extrude icon from the SubD toolbar it works fine, despite the extrude option not being visible in the Gumball.
As said before, if Reflect is broken then the extrude option after subdividing appears in the Gumball and works fine
