I’m using ctrl-q which worked fine in rh7 (is there something about it normally being tied to “exit” that’s a problem? I get rid of hotkeys for “exit” to make sure I don’t exit with a typo when I’m tired)
The other weird thing is that when the toolbar does pop up, by repeating the command, the buttons in the toolbar don’t work. In Rhino 7 they work fine. All they do is change object colors to a bunch of pre-chosen high contrast colors. I use this to streamline RhinoCAM toolpath making.
The commands in the buttons look like this:
noecho
! _Select _Pause _Pause
-Properties O C O
254,254,254
Enter Enter
_SelNone
SystemInfo results:
Rhino 8 SR3 2023-12-12 (Rhino 8, 8.3.23346.14001, Git hash:master @ 3b8659a0557b596b2d172939093022d2b67fd2e1)
License type: Commercial, build 2023-12-12
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 11-16-2022 (M-D-Y).
Primary OpenGL: NVIDIA Quadro RTX 5000 (NVidia) Memory: 16GB, Driver date: 3-9-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.79
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-9-2023
Driver Version: 31.0.15.2879
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\Users\revma\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\ColorPicker (336da4ab-03d3-42ca-b1fb-313bfd4c1157)\2019.2.15.811\ColorPicker.rhp “ColorPicker”
C:\Program Files\Rhino 7\Plug-ins\RhinoCAM 2023 for R7\RhinoCAM 2023 For Rhino7.0.rhp “RhinoCAM 2023 - The cutting edge CAM plug-in for Rhino 7.0 from MecSoft Corporation”
C:\Program Files\Rhino 7\Plug-ins\RhinoCAM 2023 for R7\RhinoArt1FileExporter For Rhino7.0.rhp “RhinoArt1FileExporter”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.23346.14001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.23346.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.23346.14001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.23346.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.23346.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.23346.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.23346.14001
