Populate 3d surface with small extruded shapes in Grasshopper
This is more or less the effect I want to achieve, probably on a smaller scale since I think it’s pretty heavy to process all that geometry.
This is the surface I want to populate in correspondence of the points:
And these are some small extrusions I made to place on each point on the surface:
What I would like to do is to randomly choose one of the four extrusions and place it on each point on the base surface, possibly having also the chance to make a boolean addition at the end.
Thank you very much in advance for you suggestions.
PS5 logos on handle.3dm (5.0 MB)
A start could be doing circle-packing on the shape, with some leniency regarding their overlap, then orienting the extrusions to the base planes of those circles. Alternatively, you could get the planes at each point on the shape (without circle-packing), randomly rotate these planes, and then orient the extrusions.
pop_geo_2024Jan25a.gh (11.0 KB)
populate with triremesh v0.gh (107.1 KB)
As for how to boolean them…hmm… maybe try voxel tools or just fusion 360.
That’s what I was looking for, thank you very much.
Thanks for your reply.
Hi Joseph! this is super!!! But is there a way to choose quantities for each piece? I’m using this example to place pieces on a Christmas tree with four different elements.
Yes, rather easily. In the process, I added a feature to cull points near the edge (purple groups). The sliders connected to Entwine set the quantity of each “symbol”. There are two ‘Seed’ sliders, one connected to PopGeo (as before) and another connected to Jitter.
NOTE: I belatedly found (and fixed :question:) a bug related to culling points near the edge… But as I type this, I just realized that culling edge points fails to guaranty that all symbols will be seen :interrobang: This bothers me but I don’t see a solution at the moment. :thinking:
pop_geo_2025Sep29aa.gh (21.6 KB)
P.S. The only expedient thing I can think of is to rip out the feature to cull points near the edge (purple groups) and leave it to “the user” to be aware of the problem and supply a slightly smaller surface to PopGeo.
pop_geo_2025Sep29b.gh (15.1 KB)
I also failed to post the correct file matching the graphic image, so fixed that by replacing pop_geo_2025Sep29a.gh with pop_geo_2025Sep29aa.gh. :roll_eyes:
Help me out folks, this is bugging me…
I’m sure I saw a really cool texture like this applied to a playstation controller surface.
I’ve searched but can’t find the topic on here or elsewhere.
@DanielPiker did you do something like this once?
https://discourse.mcneel.com/search?q=playstation%20controller
:roll_eyes:
yeah, see what I mean. It doesn’t appear in those results.
Thank you! This is the one. This is beautiful work.
I’m not going mad, just no good at searching!
Hi! I’m back again, a year later! I’ve been trying to modify your work (although I still don’t quite understand it, hahaha), but I haven’t been able to bake each type of piece separately (in different layers of Rhino, for example). I was using this to decorate a Christmas tree with ornaments (it was super useful), but what happens if we have four identical ornaments of different colors? After baking, they all look the same.
Hah, hah. That’s IMPORTANT when you modify someone’s work. I don’t remember this code but could figure it out if you had posted any code. Christmas ornaments are a totally different context than what this thread was about?
Oh! Sorry! This thread was about populating a 3D surface with small extruded shapes, and it was very helpful for what I needed. I’ll try to make a new thread :frowning: I hope I understand how to do it and don’t get lost in the translation. And I hope I haven’t bothered you!
