Polyline from list of points workflow & offset abnormalities
Hi!
I’m new to Grasshopper; I have some experience in BIM (Autodesk Revit, Tekla Structures), and I’m intrigued by Grasshopper and what it is capable of, so I’ve decided to try and learn and see how far I can get. So far, I’ve watched the introduction videos from Grasshopper3d.com (David Rutten), read some tutorials, and tried a couple of definitions.
As an exercise, I’m trying to replicate the structure of an earlier project in our firm (I work in an engineering and architecture company). We received a DWG-file with a top view and side view of the centerline (reference line) of a ride in an amusement park. Positions of all other structures (left track, right track, supporting beams, …) are all based on this reference line. (At the time of this project, another company modelled these structures, from which point we could start with engineering). My goal is to create Tekla Structures geometry based on my Grasshopper definition.
But first things first, I’ve gotten as far as this:
  • measure coördinates of points on reference line in the DWG
  • create these points in Grasshopper (I’ve created all points seperately)
  • between start and end points of bends, I generate a number of points with Evaluate-components (X and Y with formula of circle, Z with dividing the heigth in a number of steps)
  • start and end points of straight lines, and all generated points in bends are grouped, and then a polyline is created from them
  • after using offset on this polyline, I notice strange effects, particularly where bend becomes straight, or vice versa. The reference polyline looks good, the offsets don’t
What am I doing wrong?
Hints on how this workflow can be improved? (I’m guessing what I’m doing is far from efficient)
Thanks in advance!
David
Test coaster reference line offset.gh (61.7 KB)
Before digging any deeper, a glance at the canvas tells me that this can be improved with a better understanding of GH lists and data trees.
I see just one anomaly in the original polyline, likely due to mis-ordered points, which also affects the two offset curves.
Later… I fixed that anomaly by sorting one of the sets of points by their ‘Y’ coordinate, but this is not a universal solution. Better to figure out why they were mixed up?
Then I noticed that the offset curves were broken into segments on the “outside” curves, so replaced the standard Offset curve with the Clipper plugin PolyOffset which produces both offset polylines from a single ‘D’ (Distance) value. But that doesn’t work well at all!!
Next, I tried replacing PLine with Interpolate and immediately noticed different anomalies that suggest duplicate points? But CullPt removed only one point out of 442 and didn’t fix the problem… until I numbered the points, saw the duplicate points and increased the CullPt ‘T’ (Tolerance) value from ‘0.1’ to ‘1.0’, which fixes the problem!
coaster_ offset_2018Feb21a.gh (66.0 KB)
This could be a workaround for you…
Test coaster reference line offset_re.gh (62.5 KB)
I have an explanation and fix for the points being out of sequence. It’s because of the sequence in which the wires were connected to the Pt param component. That problem can be avoided by using Merge to explicitly define the sequence:
coaster_ offset_2018Feb21b.gh (73.2 KB)
Hi @davidelsayeh,
Maybe this helps with the proper offset part of your script (see the attached gh file)
best,
Lina
Test coaster reference line offset_reLina.gh (68.0 KB)
missing
Bummer. Looks like it goes here?
missing2
This method of Offset looks more complex than necessary to me? How is it different than using Offset in the opposite direction (negative ‘D’)?
Hi Joseph_Oster,
Yes it seems more complex, but I prefer doing it this way when working with complex curves due to accuracy issues (see the distance between two lines), also I can then easily manipulate the distance between curves, since the “Offset” component works much slower (but maybe it is just my pc)
Any ides how to be more efficient here and fix the issues will be much appreciated :slight_smile:
best,
Lina
At the risk of sounding argumentative, I don’t think these reasons stand up to close scrutiny. The accuracy issue is distorted by your measurement method. You are measuring the lines you created for lofting and they are all identical in length - that’s no surprise. A more accurate measurement is the distance between the two closest points (one on each curve) to each point on the center line:
offset_reLina_2018Feb22a.gh (74.4 KB)
As to the Offset component, your method already relies on using it once so what’s wrong with using it twice? As to the ability to “easily manipulate the distance between curves”, that’s trivial. And the same measurement of accuracy yields very good results:
Wow, thank you people so much!
First thing I did when I read @Joseph_Oster 's reply was learn more about lists and data trees… This indeed could have prevented a LOT of unnecessary work. Part of my learning process, I guess :slight_smile:
Duplicate points probably come from using a wrong workflow, but I know where I went wrong on this. (If someone else somehow wants to know more about my mistakes, I’ll elaborate, but I won’t bore you with the details now).
I’ll test all of your solutions and let you know how it goes!
Thanks again!
David
I made a mistake in this code I posted yesterday. Instead of connecting both offset curves to Graft, I used the centerline instead of the original Offset curve. Fixed below:
offset_reLina_2018Feb23a.gh (74.9 KB)
