Multi Offset
Hi everyone,
Different surfaces have reference curves on them. I’m offsetting the curves. Then I will ectend them to fit the surface and project them onto the surface. But when I do the project, the curves come together. I did something for this but I need to list the offsets one by one. Is there any way I can shorten this?
Thank you from now.
Multi Offset.gh (20.4 KB)
Is this what you want?
Multi Offset_re.gh (14.3 KB)
Thank you for your answer. I admire the grasshopper more and more every day.
I want to divide the resulting curves. However, the plugin I want to use does not allow this.
It gives me this problem:
  1. Solution exception:Object reference not set to an instance of an object.
    Multi Offset and divide.gh (18.1 KB)
Are you looking for Divide Curve or Divide Length ?
(Also, Pull Curve and Is Planar clean the definition)
Multi Offset and divide_re.gh (12.9 KB)
The distance between points should be constant. I also need to see the end point of the curve.
So the correct component is Divide Length and you must add the end point using End Points. Use Merge to merge your list of intermediate points and the last one.
Multi Offset and divide_re.gh (14.3 KB)
