Points of offset curves with Loose=Yes not opposite(or perpendicular)
Hi. Points of offset closed curves with Loose=Yes not opposite (or perpendicular) of the offset curves. I have rhino 8 but I think the issue RH-81146 does not work well. I want to trim loose offsets. with the same points numbers. picture attached. and I use Corel draw now. Corel draw Picture below. look at inside the letter M it is not offset 100%. and there are curves not closed. The Red Curve is the main, the blue is the offset curve. I post this problem on Mars 2024 on this platform with Rhino 6. any help please.
this is the rhino file
Maria 1.3dm (230.6 KB)
this is the Corel draw file Maria 3.cdr
