Points Drag Distorts Object
Select this rectilinear object with radiussed corners
Turn on Solid Object Points
Drag points orthoganally
Rhino thinks and thinks.
Chaos Ensues.
Any suggestions?
The project and a video of the problem is below.
PointsDragDistortsObject.3dm (930.4 KB)
POintsDragDistortsObject
Hello- run DivideAlongCreases > SplitAtTangents=Yes on the object first to split single faces at curvature discontinuites.
Thanks Pascal.
  1. Any thoughts on how one gets surface discontinuities from sweeping the section shape around a rectangle to make this door frame? (Could the units have been too coarse for the fineness of the curves that were swept?)
  2. The ā€œWhatā€ command says the object is a valid polysurface. Is that usual for an object with surface discontinuities?
The object is valid but some things work less well or not at all if a surface has curvature discontinuities - that is, it has spans that are only tangent continuous with neighboring spans - surfaces prefer to be curvature continuous. I don’t know what the inputs were but very likely SimplifyCrv on these could have helped. In general I try to keep surfaces split up - things just work better. There has been a good deal of back and forth over the years about how to handle this - sometimes it does make sense not to split things up. Just keep that DivideAlongCreases command in your hip pocket.
I"ve been using Rhino for four years now, but I don’t understand the concept of splitting in this context. I guess I’d better learn more. Not sure how to go about it. I take it ā€œDivideAlongCreasesā€ somehow ā€œsplitsā€ an object at these tangent-continuous-but-not-curvature-continuous joints. (Are they creases? I thought creases were coincident edges between spans with neither sort of continuity.) And this is a sort of splitting which doesn’t seem to compromise the closedness of a joint. I took a look at the help files for these commands, but got into a circular loop which seemed to require more understanding than I have.
Hello- there will be ā€˜fully multiple’ knots at these locations - creases in wating as it were - if you were to move a control point that is there, well, other than in a constrained way perhaps, a crease (G0) would develop.
Thanks. This leads me to attempt to understand what ā€œdividingā€ does to the geometry to solve this problem. It doesn’t seem to separate the surfaces, since the objects remain closed.
If the command were ā€œReplaceAndRepairAllFully MultipleKnotsā€ (like with micro edges) I’d sort of get it, but this command seems to be doing more of a transformation.
Hello- it makes a single curvature-discontinuous surface into multiple faces - these are joined but explodeable into separate surfaces. These behave better in many ways and (in my experience) are generally preferable if there is not a need for a single surface.
Thanks Pascal. This has been helpful. I think I need to clarify what a crease is. I’ve been under the impression that it’s a boundary of discontinuous curvature between surfaces. Based on your input here, it sounds like it can be a sharp kink in a single surface. This brings up an area of weak understanding for me - the difference between a knot, a crease, and a kink (if kink’s a Rhino term.) I’ve searched Help for definitions, but only operations instructions arise. If you can point me in the right direction, I’d appreciate it.
I think creases and kinks are basically the same - I guess a kink might be for curves and creases perhaps more referring to surfaces - I don’t know if that is strictly true. Where there are degree number of knots in the same place on a curve or surface (= ā€œfully multiple knotā€), the geometry can be and often is, smooth across that location but it’s fragile - edits to the conrol point that is there (it will be on the surface or curve) will or can, cause a tangent discontinuity ( = an actual kink or crease)
Smooth, in this case G2
But there is a fully multiple knot in the middle:
Moving that point makes a kink form
That is why point-edting a sphere, for example, gets messy very quickly unless you Rebuild it first (removes the fully multiple knots that are at each quadrant, at the expense of true-sphereness), or constrain the point movements to a very small subset.
