Since the latest update I cannot see points both from Rhino nor Grasshopper in the viewport. Though I am able to select them and can see the Gumball, but they are not displayed.
I already tried bunch of things in properties under display modes and objects.
I am running Rhino 6 on a vmware virtual machine 11.1.0 with windows 7.
Version 6 SR16
(6.16.19190.7001, 7/9/2019)
Hello - I guess this is the problem - there’s no indication what the actual underlying video support is, but it is unlikely that after passing through VM Ware it is using its full abilities.
still the same problem and colleague with VMWare has the same problem. In earlier versions of Rhino 6 it was working fine.
The mac version of Rhino also doesn’t create any problems.
Hi - the system requirements for Rhino 6 specify OpenGL 4.1.
Apart from that, VMWare and other virtualization systems are not supported.
On Mac, we recommend using the Mac version of Rhino or, alternatively, Boot Camp to boot into Windows.
To get started with DX11, VMware Tools needs to be upgraded, and the Virtual Hardware Compatibility version must be set to v18. Existing VMs can be upgraded by adjusting the virtual hardware compatibility while the VM is powered off. After power-on, you can then upgrade VMware tools as you normally would. With new VMs you may need to manually set the virtual hardware version to v18 before installing, so double check.
