The pop-up panel for PointDeviation does not allow typed leading zero before decimal point input for values less than 1 in the Ignore: and Bad point: fields. It is allowed in the Good point: field. After a value is successfully entered without a leading zero the display then shows a leading zero for values less than 1.
Example file: PointDeviationEx01DC.3dm (1.6 MB)
Open the file, start PointDeviation, select the points as the point input and the curve to test. Then try to change the Ignore field by entering 0.8 or the Bad Point field by entering 0.3. In one of those fields when a zero is typed followed by a “.” the field immediately reverts to the previous value.
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 12-29-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.09
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-29-2021
Driver Version: 30.0.15.1109
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Orca3D V2\Orca3D.rhp “Orca3D” 2.0.22.0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Hi David - yeah, I see this is messy, thanks. @davidcockey - so, there is a delay set there, where Rhino checks to see if the number is valid - (larger than the next setting down) which is way too short. You can change this however -
I doubled it here to 1.5 and this dialog seems much more tractable. But, the real question is, should this checking be there at all?.. we are reviewing…
RH-67859 PointDeviation: revise how numeric input is handled
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
