Hello, I want to change the hairscale in pointdeviation pop up window.,
it doesn’t work.
can this be solved?
I have the same problem in Rhino 7.14. There is also a problem with bad point: when I try to type “0.7” zero is ignored.
Hi Problem is still not solved, hope to get a reaction from the Rhino developers, at the moment I’m working in Rhino 6 again to get around this problem.
Hello Wim,
I can change the number for the hairscale, but the scale remains the same. I asked my colleague overhere and he experience the same.
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR17 2022-3-22 (Rhino 7, 7.17.22081.03001, Git hash:master @ e429706ef2564517d368a193809c158c4fe9e7b3)
License type: Commercial, build 2022-03-22
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display and OpenGL: NVIDIA Quadro M2000M (NVidia) Memory: 4GB, Driver date: 7-1-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.94
Integrated accelerated graphics device with 4 adapter port(s)
Windows Main Display is laptop’s integrated screen or built-in port
Secondary monitor attached to adapter port #1
Secondary graphics devices.
Intel(R) HD Graphics 530 (Intel) Memory: 1GB, Driver date: 10-14-2020 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-1-2021
Driver Version: 27.21.14.6294
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\SimLab\Plugins\SimLab JT To Rhino 6\plugins\SimLabJTImporter.rhp “SimLab JT Importer”
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Users\Albert\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18353.6521\5.5\Flamingo.nXt.rhp “Flamingo nXt 5.5” 5.5.18353.6521
C:\Users\Albert\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.17.22081.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.17.22081.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.17.22081.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.17.22081.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.17.22081.3001
Hello- that one was fixed the other day - https://mcneel.myjetbrains.com/youtrack/issue/RH-68001
Okay, so what do I need to do? I think I’m fully updated?
And the issue still remains….
Please advice
Hi Albert -
What happens when you rotate the view? I filed a bug for those hairs getting clipped depending on the view - RH-68110.
Hello- this is fixed in 7.18, which is not available yet.
