PointDeviation - all statistics are zero
(This is an updated and corrected version of a previous post)
The statistics from PointDeviation are all 0.00000 on my desktop, both in the pop-up panel and in the bar with the command line. SystemInfo results are below. On my laptop which is running the same version of Rhino PointDeviation is working properly.
Any suggestions? My work is currently impeded.
Version 6 SR14
(6.14.19070.20311, 3/11/2019)
Rhino 6 SR14 2019-3-11 (Rhino 6, 6.14.19070.20311, Git hash:master @ 5096acdcc8ad5a4d816c8eb9620eb33208eaba6f)
License type: Commercial, build 2019-03-11
License details: Cloud Zoo. In use by: David Cockey ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-7M1R2N0
Non-hybrid graphics.
Primary display and OpenGL: AMD Radeon HD 7700 Series (AMD) Memory: 2GB, Driver date: 2-20-2019 (M-D-Y). OpenGL Ver: 4.6.13547 Compatibility Profile Context 25.20.15025.1002
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 2-20-2019
Driver Version: 25.20.15025.1002
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.14.19070.20311
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.14.19070.20311
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.14.19070.20311
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.14.19070.20311
More information:
PointDeviation in V7 WIP on the same machine is working properly. It appears the problem is in the installation of V6 on that machine.
Rhino 7 SR0 2019-3-12 (Rhino WIP, 7.0.19071.12355, Git hash:master @ 9e47371db33ea6497635de7a7d6fa22ba3d6c660) License type: Commercial, build 2019-03-12
Solved. The “Ignore” value in the pop-up window had been set to 0. Reset to a non-zero value and PointDeviation is working properly.
Perhaps there should be a check that the Ignore value is larger than the other values.
Apparently there is a check - and you’re it. :smile:
