My WIP build is the following: 6.0.17073.13071, 14/03/2017. Please check if yours is previous.
As for the missing translation on top of the dialog (PointDeviation, which should be Punktabweichung) I am going to look into it and let you know when the issue is solved. Thanks for your feedback!
My Wip is 6.0.17080.23331, 21.03.2017.
Because of a material issue, I enabled daily builds in order to check the result.
But after that, I disabled daily builds, so in future I will get the normal WIPs again.
Perhaps the L is a T, and the microscopic button size clips a part of the T.
Next issue:
When I call the Point Deviation panel from the panels menu:
Befehl: _-PointDeviation
Zu testende Punkte und Polygonnetze auswählen ( Sichtbar=Nein ): _Visible
Sichtbar ( Ja Nein Umschalten ): _Toggle
Unbekannter Befehl: _Toggle
Sichtbar ( Ja Nein Umschalten ): Ja
I must click ‘Ja’ in the command line to get the panel.
This shouldn’t be, or?
Sorry, but I got no idea what might go wrong with your version. In order to get help, and also for the following issue you’re pointing out, maybe you should contact our technical support team (tech.eu@mcneel.com).
But I know:
The clipped text is a DPI issue.
And the button size is ridiculous.
[quote] In order to get help, and also for the following issue you’re pointing out, maybe you should contact our technical support team (tech.eu@mcneel.com).
[/quote]
I thought I’m in the Serengeti.
As far as I understand, the technical department gets support, hints, error reports and ideas from the users in here.
Hmm.
