When I try to export a pointcloud as a .PLY file I get the error -
" Failed to save as D:| blah blah … .Ply
The file writing plugin failed."
I have done this before without any issues.
Regards,
Mike.
Regards,
Mike.
Hi Mike - is this true with any point cloud? Just make half a dozen point objects, run PointCloud on them, Export - does that much work?
Hmmm… that worked.
Could it be a size limit ? The pointcloud is about 120,000,000 points.
I can export it as a TXT file no poroblems.
Hi Mike- can we get the file? The developer thinks it ought to work with that many - if you can, please send to www.rhino3d.com/upload to my attention. Please include a link back here in your comments.
Are you exporting binary or text format?
Uploading now.
I have tried Ascii and Binary, I get the same warning.
_Mike.
Hm - upload is failing - is the file massive?
Hey Tobias,
Any chance you could share one of the files that doesn’t work? Then we can dig through it in a debugger.
Tim
@tim I will see to get it uploaded after the holidays.
