Hello
a strange thing happens to me between the plugins of the mcnell, practically are all mixed between version 6.5 and 7.
I noticed this because I was exporting to iges and the prompt
this message appeared:
Testing C:\Program Files\Rhino WIP\Plug-ins\export_IGES.rhp (and 29 other assemblies) for compatibility…
Compatibility test succeeded in 9.15s
the IGES export plugin is version 7.0…
in the details says
Guid 7f0ca561-0c7c-4cea-b822-b95ebe71c409
file name C:\Program Files\Rhino WIP\Plug-ins\export_IGES.rhp
route register \HKEY_CURRENT_USER\Software\McNeel\Rhinoceros\HKEY.0\Plug-Ins\f0ca561-0c7c-4cea-b822-b95ebe71c409
I have 67 plugins version 7
some perform the compatibility test when I recall them others give me incompatible version as for peshtools and squish for example
Same problem on different pc but less confused plugins
Plugin List
Name>SlicerTool - Version>1,0,0,1
Name>SolidTools - Version>6,5,18155,13161
Name>Commands - Version>6,5,18155,13161
Name>import_3MF - Version>7,0,18163,3305
Name>Export_FBX - Version>7,0,18163,3305
Name>MeshFromPoints - Version>6,5,18155,13161
Name>RhinoScript Editor - Version>6,5,18155,13161
Name>WebBrowser - Version>6,5,18155,13161
Name>Import_FBX - Version>7,0,18163,3305
Name>PaveDataBaseTool - Version>1,0,0,1
Name>PaveTool - Version>1,0,0,1
Name>Trace - Version>1,3,0,0
Name>Renderer Development Kit - Version>6,5,18155,13161
Name>ACIS Export - Version>7,0,18163,3305
Name>ZCorp Import - Version>7,0,18163,3305
Name>MicroStation file import: import_DGN - Version>7,0,18163,3305
Name>Lightwave Import - Version>7,0,18163,3305
Name>RhinoScript - Version>6,5,18155,13161
Name>Iris - Version>1,0,0,0
Name>RPC - Version>6,5,18155,13161
Name>VRML Import - Version>7,0,18163,3305
Name>Rhino Bonus Tools - Version>6,5,18155,13161
Name>export_3MF - Version>7,0,18163,3305
Name>X Export - Version>7,0,18163,3305
Name>Rhino Labs Tools - Version>6,5,18155,13161
Name>Raw Triangles Export - Version>7,0,18163,3305
Name>STL Export - Version>6,5,18155,13161
Name>Import_AMF - Version>7,0,18163,3305
Name>Faro Digitizer - Version>7,0,18163,3305
Name>Frog6 - Version>1,0,0,0
Name>SLC Import - Version>7,0,18163,3305
Name>OrientTool - Version>1,0,0,1
Name>ScoopTool - Version>1,0,0,1
Name>Import_DST - Version>7,0,18163,3305
Name>AutoCAD file export : export_ACAD - Version>7,0,18163,3305
Name>AnimationTools - Version>6,5,18155,13161
Name>IdleProcessor - Version>6,5,18155,13161
Name>Lightwave Export - Version>7,0,18163,3305
Name>Windows Metafile Export - Version>7,0,18163,3305
Name>VRML/X3D Export - Version>7,0,18163,3305
Name>Squish - Version>7,0,18163,3305
Name>export_OBJ - Version>6,5,18155,13161
Name>Adobe Illustrator Export - Version>7,0,18163,3305
Name>XGL Export - Version>7,0,18163,3305
Name>Import_M - Version>7,0,18163,3305
Name>CreaseAngle - Version>7,0,18163,3305
Name>Mesh2 - Version>1,0,1,0
Name>Points Export - Version>7,0,18163,3305
Name>ZCorp Export - Version>7,0,18163,3305
Name>BooleanTool - Version>1,0,0,1
Name>OFF Import - Version>7,0,18163,3305
Name>Rhino Render - Version>6,5,18155,13161
Name>AuroraJewels6 - Version>1,0,0,0
Name>ArtTool - Version>1,0,0,1
Name>GemTool - Version>1,0,0,1
Name>RDK_EtoUI - Version>6,5,18155,13161
Name>Renderer Development Kit UI - Version>6,5,18155,13161
Name>SketchUp Export - Version>7,0,18163,3305
Name>PipeTool - Version>1,0,0,1
Name>POV-Ray Export - Version>7,0,18163,3305
Name>Tutorials - Version>6,5,18155,13161
Name>PLY - Polygon File Format Import - Version>7,0,18163,3305
Name>AutoCAD file import: import_ACAD - Version>7,0,18163,3305
Name>SplopTool - Version>1,0,0,1
Name>Snapshots - Version>6,5,18155,13161
Name>STEP Import - Version>6,5,18155,13161
Name>DrillTool - Version>1,0,0,1
Name>RingNetTool - Version>1,0,0,1
Name>Renderman Export - Version>7,0,18163,3305
Name>MeshCommands - Version>6,5,18155,13161
Name>MicroScribe Digitizer - Version>7,0,18163,3305
Name>Alerter - Version>6,5,18155,13161
Name>CordaTool - Version>1,0,0,1
Name>STEP Export - Version>7,0,18163,3305
Name>Rhino Options Manager - Version>6,5,18155,13161
Name>IGES Export Plug-in - Version>7,0,18163,3305
Name>WAMIT Export - Version>7,0,18163,3305
Name>IronPython - Version>6,5,18155,13161
Name>IGES Import Plug-in - Version>6,5,18155,13161
Name>VDA Export - Version>7,0,18163,3305
Name>X Import - Version>7,0,18163,3305
Name>RAW Triangle Import - Version>7,0,18163,3305
Name>SLC Export - Version>7,0,18163,3305
Name>PDFReader - Version>7,0,18163,3305
Name>RPTool - Version>1,0,0,1
Name>Walkabout - Version>7,0,18163,3305
Name>Moray Export - Version>7,0,18163,3305
Name>NextEngine Import - Version>7,0,18163,3305
Name>RhinoCycles - Version>6,5,18155,13161
Name>MeshTools - Version>7,0,18163,3305
Name>Gopher - Version>1,0,0,0
Name>GTS Export - Version>7,0,18163,3305
Name>AuxpeckerStudio3 - Version>3,0,0,0
Name>Romer Digitizer - Version>7,0,18163,3305
Name>WAMIT import - Version>7,0,18163,3305
Name>Grasshopper - Version>6,5,18155,13161
Name>export_xaml - Version>7,0,18163,3305
Name>TBTool - Version>1,0,0,1
Name>AuroraJewelsTools6 - Version>6,0,0,0
Name>Export SVG - Version>7,0,18163,3305
Name>STL Import - Version>6,5,18155,13161
Name>VDA Import - Version>7,0,18163,3305
Name>CutTool - Version>1,0,0,1
Name>SketchUp Import - Version>7,0,18163,3305
Name>PLY - Polygon File Format Export - Version>7,0,18163,3305
Name>Cult3D Export - Version>7,0,18163,3305
Name>General Hydrostatics (GHS) Export - Version>7,0,18163,3305
Name>CurveTool - Version>1,0,0,1
Name>RhinoLibrary6 - Version>1,0,0,0
Name>StripTool - Version>1,0,0,1
Name>PDF Export - Version>6,5,18155,13161
Name>Export_DAE - Version>7,0,18163,3305
Name>Toolbars - Version>6,5,18155,13161
Name>3Dconnexion 3D Mouse - Version>6,5,18155,13161
Name>Solidworks Import - Version>7,0,18163,3305
Name>3D Studio Export - Version>7,0,18163,3305
Name>RingResizeTool - Version>1,0,0,1
Name>Parasolid Export - Version>7,0,18163,3305
Name>Faro USB Digitizer - Version>7,0,18163,3305
Name>General Hydrostatics (GHS) Import - Version>7,0,18163,3305
Name>Export_AMF - Version>7,0,18163,3305
Name>InstanceTool - Version>1,0,0,1
Name>Comma Separated Value Export - Version>7,0,18163,3305
Name>E57 Import - Version>7,0,18163,3305
Name>Points Import - Version>7,0,18163,3305
Name>BlockEdit - Version>6,5,18155,13161
Name>Displacement - Version>6,5,18155,13161
Name>MPlane - Version>7,0,18163,3305
Name>Import_SVG - Version>7,0,18163,3305
Name>Calc - Version>6,5,18155,13161
Name>GTS Triangle Import - Version>7,0,18163,3305
Name>Import_OBJ - Version>6,5,18155,13161
Name>Named Position - Version>6,5,18155,13161
