please help
does anyone know whether you used to be able to pan the views by pressing and holding the middle mouse button/scroll wheel and right click to orbit or rotate the views?
for some reasons, now when I click or press on my middle mouse button/scroll wheel it acts if I pressed spacekey or right click it just give the last command I used instead of panning.
Am I trippin or was there at one point where you can do that?
I tried but could you tell which one I should pick in order to make my middle button/scroll wheel button to work as a pan instead of giving me my last used command? please
Hello- none of this makes any sense to me - Planar has nothing to do with view manipulation. Set the settings I posted above to pan on middle mouse button and you should be set. If you want to run a macro instead, 'Pan should work but the first way is probably easier with just mouse-down and drag to pan.
Hello- there is nothing in the settings you show that would lead me to expect the MMB to pan.Tcking the box for ‘manipulate view’, on the other hand, should not do exactly what you are asking.
