Hello!
I wrote a Grasshopper Component that creates a mesh (geodome), and would like to allow the user (me : ) to transform the mesh into place in some way - parametrically (position, rotation, and maybe scale).
For that I use a GH ‘Plane’ object of course, which can be placed interactively by ‘Set one Plane’, position and rotation (no scaling, though).
But what when the plane should be derived from some scene object instead of interactively placing it? And what if I need scaling, too?
Basically, a GH Plane is a transformation matrix, right?
There seems to be no 1:1 equivalent to the GH Plane in Rhino. If I bake it, I end up with a ‘PlaneSurface’, a NURBS surface - that’s seemingly as close at it gets.
Yet, vice versa, when I create a ‘Plane Surface’ (command ‘Plane’) in Rhino, I cannot pick it from the GH ‘Plane’ component.
Isn’t that somewhat inconsistent?
So, I could use a ‘GH Surface’ node to get the plane surface. But how do I derive a transform from it?
Access it’s Gumball? How is that done in code?
Then, in the SDK, there’s the Rhino.Geometry.Transform object (which I use in Python), but it, too, has no 1:1 equivalent in the Rhino scene, has it? (From a Python component, I tried to bake an output variable of type ‘Transform’, but got nothing)
In most other 3d-programs, ‘transforms’ exists and is shown as an axis cross or tripod.
In Cinema4D or Softimage this is called a ‘Null’.
In 3ds Max and Maya, this is called ‘Point’ (unlike the Rhino Point is contains a complete 4x4 matrix).
Ain’t this missing in Rhino? (I know, i know, CAD-program and such… )
However, there seems to be a paradigm to avoid such a thing. Is there a reason for this?
Thanks for reading!
Best regards
Eugen
