RIR : Parameter "x" type conversion failed from GH_Plane to Plane
Hello
when trying to pass Plane to C# component in rhino inside , it`s fails to cast it to rhino Plane
[Window Title]
Rhino.Inside - About
[Main Instruction]
Rhino.Inside© for Revit
[Content]
Rhino.Inside Revit: 1.32.9217.15361 (2025-03-27T08:32:02)
[Expanded Information]
Rhino: 8.18.25100.11001 (Rhino 8)
Revit: 2023.1.60 (23.1.60.36)
CLR: 4.0.30319.42000 (4.8.9300.0)
OS: Microsoft Windows NT 10.0.26100.0
[^] Hide details [Web site] [Read license] [See source code] [OK]
[Footer]
Press CTRL+C to copy this information to Clipboard
Are you trying to Convert this into Revit Plane? If yes Please check the following Documentation
Hello Muhammad
Component fails to to convert the Plane From GH object to Rhino object
@mohamed3 Does this file throw an error for you in RIR?
Plane.gh (3.2 KB)
it didn’t at first , but when trying to edit , it throw same error
Try this now and see if the input data is unwrapped as Rhino.Geomtry.Plane
Plane.gh (6.7 KB)
Again , work properly in the beginning
That’s very odd. Okay let me test this on my Windows machine and will update here again.
@mohamed3 I can successfully replicate that here and will push a fix for this soon. Is that recently started happening?
RH-87071 Param conversion fails in C# script in Rhino.Inside.Revit
Yes , it was working okay in previous versions rhino and rhino inside .
Thanks @eirannejad
