PlanBee is a plug-in intended to help compute and visualize the features of a floor plan at variable resolutions and in doing so to help the designer look at the programmatic organization of the floor plan from a different vantage point. Use the Rendered view mode when using PlanBee to make the most of built in analysis/display components. All analysis components support parallel computing.
Besides computing various metrics across different floor plan locations, PlanBee offers the implementation of a Kohonen Self-Organizing Feature Map algorithm (SOM) to ‘self-organize’ the specified programmatic blocks of the floor plan. To understand this, it helps to think of the floor plan as a field of voxels, each of which contains values for different computed metrics. Once the metrics are calculated, each voxel corresponds to a multi-dimensional vector. The SOM basically reconciles the multi-dimensional vectors of the field of voxels with the features one specifies should belong to a programmatic mix.
Posted Feb 03, 2020 by Cécile Lamborot on Rhino News, etc.
