Pipe Issue
I am having this issue that I wish to understand. I have a closed curve that I want to pipe and when I do it it does not happen and produces overlapping structures. However, when I use mesh pipe, it works but obviously, it’s not as smooth as the poly surface.
I have attached the code and I would like to understand, why the curve works with the mesh pipe and not the pipe function.
Thank You
Pipe Question.gh (17.6 KB)
Your curve has 4 coincident control points
I see, so is there a way to remove them besides doing it manually?
This works great, Thank you.
Is there a function in grasshopper?
rebuild_nurbs_curve.gh (6.7 KB)
This is amazing, thank you for your time :slight_smile:
