Sweep1 function with closed curve in grasshopper
Hi I am working on pipe shape making.
I cannot understand why sweep1 doesn’t work to closed curves
Does anybody know what the problem is?
sweep1 problem-1.3dm (563.0 KB)
sweep1 problem-1.gh (7.7 KB)
don’t know why sweep is failing, but if you want to sweep with circular-only sections you might use Pipe instead?
sweep1 problem-1_Re.gh (10.9 KB)
I tried pipe too but the pipe is not seamless
anyway thanks for your comment Inno!
try to make Periodic = True, it should work
Thanks it works!
