Is it just me, or has the 1to1 option gone missing from the picture plane command? I always found this very convenient when working with pictures, that already had the correct size.
Hi Joerg -
That option seems available here:
When you open the command history, are you seeing different options there?
Thank you Wim,
in my example I used a .jpg as a picture plane and the ‘1 to 1’ option was missing. Seeing that you used a .png, I tried that too and voilá: The ‘1 to 1’ option is back. Upon further investigation my problem seems to apply only to .jpg images that excede a certain size. If I scale them down to 75dpi the ‘1 to 1’ option works just fine. (4512px by 1690px at 120dpi versus 2820px by 1056px at 75dpi)
(Version 8 SR1 / 8.1.23311.13281, 2023-11-07)
Hi Joerg - - Here it looks like the option simply does not appear for jpg images - jpg do not have DPI info as far as I can tell.
Hum, well they don’t all, then,… I made a couple in PS and they do not - do the ones that have dpi show the option on Picture? I would expect yes…?
Yeah, I can set dpi in jpegs that do not have it and these work with 1To1.
The jpgs in question have dpi information. In fact, i had used them in Rhino 7 two years ago to demonstrate the picture plane command to students.
Hi Joerg - can you please post an example that does not show the 1To1 oprtion?
Well durn it… can you post that image or send it to me?
I’ll send it to you as it’s proprietary…
BTW, I’m running (8.2.23338.11001, 2023-12-04) - a daily build Brian sent me yesterday.
Fake DPI news!
Joerg’s image also shows no dpi info here…
Oh, well. These are not the original values. I suspect, the image has been processed by the discourse server. It should give you 95,5cm by 35,77cm at 120dpi.
Hi Mitch, here, in PS I do not get the same info from your image. Can you please humor me and zip the file and then send it again?
You got it…
Yep, thanks OK, now I see the dpi. Maybe we can get somewhere…
