I’ve been using Rhino for 13 years and always wished I could change the level of translucency on an imported picture (plane) so I could trace dark images better. I’m trying to trace an image of truss a vendor sent and the lines are so bold - are we able to change the transparency?
You can change the transparency under the Material tab.
Thank you. : ) After checking that out, I played with other transparency controls and realized with some experimentation, you can quickly simply an image to make it even easier to trace. Nice work!
