Rhino 8 Mac transparency issue
I imported an image into Rhino using the Picture command. I want to make a image a bit faded so I can have an easier time drawing over it. There used to be a transparency slider somewhere to make images fade a bit. I can’t find it in Rhino 8.
Any help would be appreciated. Thanks in advance
Hello - the control is on the object’s material in Properties.
There is no “object’s material” in Properties for this pictures object as far as I can tell. I’ve made a screenshot, but I can’t seem to attach it here.
Found it! Thank you! I didn’t realize I had to click on the Material icon next to Properties on the top.
Upgrading to Version 8 from 5 comes with a fair amount of pain. That’s what happens when your 11 year old computer as well as the backup drive die at the same time. And you find out that 5 was no longer supported on the new OS X.
