You might consider using photogrammetry instead of laser scanning.
Photogrammetry generates the 3D coordinates of selected points, usually applied targets. Export the points to Rhino and then work with the points in Rhino.
To do this, you apply targets, take your photos from varied locations, process the images on the computer, and export the results to Rhino.
You can integrate photogrammetry into your Rhino workflow using PhotoModeler. Import solved camera positions, rotations, and undistorted image backgrounds directly in the Rhino’s native .3DM format.
A few things PhotoModeler can do:
- Comprehensive Rhino 3DM export with geometry (2D and 3D points, lines, surfaces, textures, and NURBS, layers & materials), camera position and orientation data, and two styles of image background.
- Transfer complete 3D models with NURBS, surfaces, textures, etc.
- Work with the same layers and materials in both programs.
- Transfer accurate scale and coordinate systems for accurate dimensioning.
- Transfer project notes to Rhino notes.
- Set up orthographic image backgrounds in Rhino.
- Work with 2D patterns and templates for camera-based digitization.
- Transfer an accurate camera view for each original project photo.
PhotoModeler Technologies wrote a blog post with tips for using photogrammetry and PhotoModler with Rhino.
In the photo above, the background image is in Rhino with overlaid CAD data, showing the difference between the original and adjusted photos.
Posted Aug 15, 2019 by Sandy McNeel on Rhino News, etc.
