I am not having the phenotypes out of the wallacei analysis. They are exported successfully but it can’t be converted
any help please?
Are you sure they are mesh ? turn on the decoding phenotype component to check if anything is exported or not
hi, I have the same problem as her, I’ve checked the results and I can see them in Param Viewer but cant export the phenotypes, what can be the problem here?
make sure you look at the correct outrput. If you share your file I can help you better
