Persistent sub-object identifiers
Hey everyone,
I would like to create the following setup for a box:
In which a unique label or identifier can be tied to every face as such and have it persist through non-destructive transformations (rotation, translation or scaling).:
1 - Bottom; 2 - Top; 3->6 - Sides
A specific face could later be referenced and used through its identifiers in grasshopper or in a script.
In this case, face 3 will always be the “front” of the object, so a grasshopper script can move the box to the World Origin and align the “front” to the X axis, facing towards -Y. The steps of the operation could then be applied to other objects as well, maintaining their relative positions to the box.
Is such a thing possible in Rhino?
I’m looking for the same thing. My use case: I need to boolean several objects into one, and then do a remesh operation, with the resolution of the faces determined by the objects original ‘parent’ solids.
I think the most simpel but a bit brute force approach is to create a very rough mesh per face and use the inner vertices as sample points against the parents.
Note that also geometry can hold custom data / user strings but it is not clear / documented when this data survives or gets lost for example if you attach it to a surface that is part of a brep. @dale can you please clarify this / enlight us: will user data attached to a surface/ face of a breb survive boolean operations and / or transportations ?
Thanks
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.geometrybase/setuserstring#(string,string)
Thank you @Tom_P ! I did try setting userText (in gh) for brep faces, but that info is indeed lost as soon as you join them back into a solid.
I will have to stare at your mesh idea for a while longer before it sinks in :wink:
Did you try to attach it to the underlying surface?
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.brep/surfaces
EDIT:
@declan
i did a fast test and it looks like attaching user Data to the underlaying surfaces survives boolean operations and transformations.
Interesting. Are you accessing the srfs in Rhino or gh? Would you mind sharing your test?
Using vanilla gh:
Using gh python to access Rhino.Geometry.Brep class:
in a command in a rhinocommon / c# plugin - using above link / Rhinocommon function.
my guess - vanilla gh does not access user Strings attached to geometry (only to attributes).
Just doubling back here because I saw this Material workaround mentioned in another thread.
