Perlin noise on mesh cylinder
Hey fraguada,
i did a tutorial on this plugin, and i wanted to achieve a cylinder with the perlin noise texture so that i could 3d print it. Currently there isn’t any mesh cylinder within grasshopper.
How do you think i should proceed?perlinnoise(sphehre).gh (7.9 KB)
Make a cylinder and mesh it.
Just in case you didn’t manage to do a cylinder mesh. It is not so simple because you must know the option to mesh well and also there will be a problem with the normals. A cylinder is not smooth. There is a sharp transition that is not good for normals. I use something to smooth.
