Hello, I am experiencing a major issue with a large building (80.000m2). The file isn’t that large (109MB) an it is mostly modeled in VA, made up of a mix of mainly VA elements and 3 main blocks (1 for each typical floor) repeated Ntimes. Every time I reopen the file takes a while to regenerate.
I am trying to generate Section or Elevations but it is proving impossible. VisualARQ stays on 0% while the CPU seems not to be very active on the process. Any suggestion on how to go about this?
Which version of VisualARQ and Rhino are you using?
Do you have V-Ray 4.20.03 installed? We have detected a problem between VisualARQ and the last update of V-Ray, which makes open models very slow, specially on models with blocks that contains many VisualARQ objects.
Can you send us the model to visualarq@asuni.com?
Enric
Hello, I have indeed vray 4.20.03. VisualArq 2.85 and Rhin 6 SR9.
I will send the file
