Pen Mode: Ground Flickers in Scene
When in Pen Mode, if I ‘Select All’ and try and rotate the scene the Ground (?) flickers into the scene as a dark grey plane. When you deselect, this grey plan disappears. Please see the example here:
Note that this also occurs when all the layers are are set to visibility ‘off’ (so nothing showing). In that case, the grey ground plane appears and does not go away until a layer with surface geometry is turned ‘on’ (turning on layers with only curves does not cause the grey ground to disappear).
Display Options:
Environment:
  • MacOS Sonoma 14.6.1
  • Rhino 8 (8.13.24289.13002, 2024-10-15)
System Info:
system_info.txt (4.4 KB)
all the best,
@ed.p.may
hi @ed.p.may can you export your modified pen mode, and send a sample scene that shows the behavior?
Hi @Gijs ,
Sure thing. Exported display mode attached as well as a sample scene:
example.3dm (3.2 MB)
Shaded - Render Material.ini (8.2 KB)
thanks,
@ed.p.may
thanks @ed.p.may
Are you sure you exported the correct display mode? What I see is Shaded - Render Material, and there is no groundplane
Oh whoops - I am very sorry, I attached the wrong one. Please find the right one attached here:
Pen - Render Material.ini (7.7 KB)
@ed.p.may
I am not seeing that issue you have here in 8.14
but I can reproduce in 8.13
For the time being, you can either use 8.12, or I can send you a more recent 8.14 build by pm, let me know.
Thanks @Gijs , no worries - its not a huge issue and not something that’s blocking us - just wanted to note it for addressing eventually.
@ed.p.may
thanks,
RH-84411 Groundplane shows up dark gray
