I’m after some advice in list management. I’ve created a Grasshopper definition that measures the gradient of an existing pedestrian path within a landscape and then assesses it against allowable gradients within Australian Standards AS 1428.1-2009 Design for access and mobility.
I’m able to get it to work perfectly for one pedestrian path. However, it gets messed up when I analyse two paths at the same time. Does anyone have any tips on how I can manage the lists from the two different pedestrian paths?
Here’s a screenshot of it working with one pedestrian path:
Thanks for the tip @joeallberry and thanks @HS_Kim for fixing up the Grasshopper definition for me!! I also like how you simplified the definition by projecting the points onto the curve instead of the complicated way I had done it.
