lahos
(Lahos)
1
Trying to print “extent” a selection but margins are not working properly with Rhino PDF.
It works with Microsoft Print to PDF.
I draw a letter page with 2 offset rectangles of 10 mm distance.
Here is the result of the 2 inner rectangles printed extent, 1:1 with 10 mm margins:
Regards
page_10mm_margin.3dm (26.0 KB)
test.pdf (1.7 KB)
wim
(Wim Dekeyser)
2
Hi -
That seems to be working fine here:
Print settings are not saved in the file so I’m not sure which settings you are using.
lahos
(Lahos)
3
Sorry.
Select the 2 inner rectangles and use these settings :
wim
(Wim Dekeyser)
4
Hi -
Thanks, added to RH-71708 File IO: Export to PDF: Preview shows wrong position
lahos
(Lahos)
5
According to the bug report title, the preview is fine. The output is not.
Surprised to not have it fixed in the last release SR-26.
Regards.
