Bug - Rhino PDF
When printing a Rhino pdf if we set the margins to anything other than zero the print is not centered, even thought the Centered box is checked, when created. If we leave the margins set to zero, it will center it and create it correctly.
It displays correctly in the preview window with the margins set to anything other than zero, but it does not print correctly.
Thanks,
Brent
Suggest you post an example 3dm file and the resulting pdf .
