Possible Bug : Rhino PDF margins are out
As the title suggests…
I have a drawing contained within a title block that contains a line set 5mm in from the edge of the page.
Prints out perfectly using either the ‘Windows PDF Printer’ of the ‘Adobe PDF printer’ .
If I use the ‘Rhino PDF’ printer however the drawing is offset. not to scale when printed and omits the top left hand portion of the ‘surrounding box’.
Hi Bill -
I created a layout in a new file. Drew a rectangle snapping to the corners of the layout. Then offset that rectangle 5 mm to the inside. Then used Rhino PDF to produce the PDF file. I couldn’t see anything off with that output. Do I need to do something differently to test this?
