Hello!
PDF layer support when exporting have been introduced in R7 WIP, which is great! What about layer support when importing a PDF into Rhino? Just had the case where I would have needed this.
Now there’s just one layer created, which doesn’t even have a name. (the PDF has layers for sure, tested in Affinity Designer).
Thanks!
Best regards
Eugen
Hi Eugen -
I just tested this with a round-tripping PDF and all layers came in as they should.
Can you provide a PDF file that does not do this?
Try this one please:
test layers.pdf (272.9 KB)
Thank you!
Hello Wim!
Did you find the time to test this?
Here’s another PDF that does not import with layers:
openstreetmap.pdf (900.2 KB)
When opening it Affinity Designer, all layers work.
Rhino 7.3.21026.13001
Thanks!
Best regards
Eugen
