In latest V8 WIP importing pdf’s is not behaving nicely. Slow and heavy once it appears. Also doesn’t seem to arrive with the correct scale. I can import the same drawing into V7 no problem. Strangely if I copy/paste from V7 to V8 the geometry is fine.
Hi Miles -
Could you provide the following information: your SystemInfo
, are you running on OpenGL or Metal, a simple PDF file that behaves like this?
Hi Wim, please see attached (I’ve had to delete some of the critical info from the pdf). Imports as expected in V7
PDF Test1.1.pdf (1.3 MB)
Milezee Sys Info.txt (3.8 KB)
